[GRASS-dev] Fwd: [OSGeo] #1816: upgrade Trac to 1.2 release
Vaclav Petras wenzeslaus at gmail.com
Tue Jan 10 08:15:47 PST 2017
On Tue, Jan 10, 2017 at 10:53 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi devs,
> are we really using TracMetrixPlugin? See below...
I don't know what part of Trac it is. It is this one?
https://trac.osgeo.org/grass/pdashboard
Nice overview, I used it several times just because it is there and you
don't need to do a query, but we can live without that. Perhaps there is
something similar.
> Or ditch it?
> Markus
> ---------- Forwarded message ----------
> From: OSGeo <trac_osgeo at osgeo.org>
> Date: Tue, Jan 10, 2017 at 4:36 PM
> Subject: Re: [OSGeo] #1816: upgrade Trac to 1.2 release
> To:
>  Reporter:  jmckenna  |       Owner:  strk
>      Type:  task      |      Status:  assigned
>  Priority:  normal    |   Milestone:
> Component:  Trac      |  Resolution:
>  Keywords:  trac      |
> Changes (by strk):
>  * cc: neteler (added)
> Comment:
>  SectionEdit upgraded so it will work with Trac 1.2, but TracMetrixPlugin
>  still fails and has no replacement yet, see https://trac-
>  hacks.org/ticket/13041 - The only instances using the Metrix plugin are
>  the GRASS and QGIS (deprecated) ones.
>  Markus: how useful is the Metrix plugin for you guys ?
> Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1816#comment:7>
> OSGeo <http://www.osgeo.org/>
> OSGeo committee and general foundation issue tracker.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170110/db5b8d96/attachment.html>
