Hi, I just tried to enable compression of null files, using within a session: export GRASS_COMPRESS_NULLS=1 r.null -z map=mymap This works fine, but how can I set this permanently. Can I for example use g.gisenv for that? Or do I need to set this every time when starting a new session? Regards, Paulo
