[GRASS-dev] set null compression permanently
Martin Landa
landa.martin at gmail.com
Tue Jan 10 09:05:38 PST 2017
2017-01-10 17:55 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
> This works fine, but how can I set this permanently. Can I for example use
> g.gisenv for that? Or do I need to set this every time when starting a new
> session?
it's not GRASS variable. Environmental variables can be defined in
$HOME/.grass7/bashrc (or env.bat on Windows). In your case
export GRASS_COMPRESS_NULLS=1
put to bashrc/env.bat file. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
