[GRASS-dev] v.what.rast: topology really necessary?
Martin Landa landa.martin at gmail.com
Wed Jan 11 02:26:02 PST 2017
Hi Stefan,
2017-01-10 22:49 GMT+01:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> After repeated testing, a colleague of mine pointed out that I know occupy almost all available PostGIS connections on our server.
> It seems that connections hang from testing and that either v.external or v.what.rast does not close the PG connection properly after the module finishes... Or are there other possible explanations?
I would guess that the command which segfauls could be a problem. I
tested all the commands including v.what.rast which segfaults and
check number of active connection via pg_top. No connection hanged
even I launched the command with segfault.
> Where should I look to find the source of the issue?
Install pgtop on the server, login as postgres user and run pg_top
command. It will show you number of active connection. Run GRASS
command and check number of connection.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
