[GRASS-dev] Super quiet in python script
Luca Delucchi
lucadeluge at gmail.com
Mon Jan 16 06:45:58 PST 2017
Hi devs,
it seems no possible to use -qq flag in the scripting library to run modules.
I attach a diff, please let me know if it make sense and If I can submit it.
ciao
Luca
www.lucadelu.org
Index: lib/python/script/core.py
--- lib/python/script/core.py (revision 70379)
+++ lib/python/script/core.py (working copy)
@@ -264,7 +264,7 @@
def make_command(prog, flags=b"", overwrite=False, quiet=False, verbose=False,
- errors=None, **options):
+ superquiet=False, errors=None, **options):
"""Return a list of strings suitable for use as the args parameter to
Popen() or call(). Example:
@@ -289,6 +289,8 @@
args.append(b"--q")
if verbose:
args.append(b"--v")
+ if superquiet:
+ args.append(b"--qq")
if flags:
flags = _make_val(flags)
if b'-' in flags:
@@ -330,7 +332,7 @@
returncode=returncode)
def start_command(prog, flags=b"", overwrite=False, quiet=False,
- verbose=False, **kwargs):
+ verbose=False, superquiet=False, **kwargs):
"""Returns a Popen object with the command created by make_command.
Accepts any of the arguments which Popen() accepts apart from "args"
and "shell".
@@ -550,7 +552,7 @@
def exec_command(prog, flags="", overwrite=False, quiet=False, verbose=False,
- env=None, **kwargs):
+ superquiet=False, env=None, **kwargs):
"""Interface to os.execvpe(), but with the make_command() interface.
:param str prog: GRASS module
@@ -1596,7 +1598,7 @@
except ValueError as e:
_debug_level = 0
sys.stderr.write(_("WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {}\n").format(e))
return _debug_level
