[GRASS-dev] v.clean rmarea
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Jan 20 11:37:42 PST 2017
Hi devs,
I am trying to clean a map using v.clean. When using rmarea, any
threshold values > 0.45 for rmarea results in 'ERROR: Failed to build
new area'. From the manual I understand that the threshold for rmarea
must be in square meters (also for latitude-longitude locations). With
areas of polygons at least being 50m2, and mostly well above 10000m2, I
am not sure what is happening, any idea?
Rgds
Paulo
