[GRASS-dev] v.clean rmarea
Markus Metz
markus.metz.giswork at gmail.com
Sat Jan 21 12:29:17 PST 2017
On Fri, Jan 20, 2017 at 8:37 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi devs,
> I am trying to clean a map using v.clean. When using rmarea, any
threshold values > 0.45 for rmarea results in 'ERROR: Failed to build new
area'.
That should not happen, it is an error in the method to remove small areas.
Can you provide the vector map for testing (offlist)?
Markus M
> From the manual I understand that the threshold for rmarea must be in
square meters (also for latitude-longitude locations). With areas of
polygons at least being 50m2, and mostly well above 10000m2, I am not sure
what is happening, any idea?
> Rgds
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170121/a3b85b33/attachment.html>
