[GRASS-dev] v.clean threshold value unit for 'prune'
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Jan 26 01:51:30 PST 2017
Hi
I am using the v.clean tool with the option "prune". According to the
manual, threshold values have to be in map units. I am using this with a
latlon map with vertices as close as 0.0001 degrees. However, v.clean
only removes vertices at threshold values of about 50 or up. This seems
to suggest that the tools assumes threshold values are in meters?
Best wishes,
Paulo
