[GRASS-dev] [GRASS GIS] #3369: Followup to area calculation fix in changeset 71169
trac at osgeo.org
Sun Jul 9 16:44:31 PDT 2017
Reporter: ndawson | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
While investigating the QGIS ticket https://issues.qgis.org/issues/16820 I
came across changeset 71169 as a fix for a similar issue in grass.
When porting this fix across to QGIS, I had to modify the thres constant
value to 0.7e-7, outside of the 1e-4 to 1e-7 range noted in the comment in
area_poly1.c. I found this to be the maximum possible value which allowed
an existing QGIS regression test to pass:
https://github.com/qgis/QGIS/blob/master/tests/src/core/testqgsdistancearea.cpp#L371
(as a result of https://issues.qgis.org/issues/14675)
So this ticket is just a heads-up that the grass threshold value of 1e-6
may not be suitable, and this may need lowering to fix a real-world area
calculation issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3369>
