[GRASS-dev] [GRASS GIS] #3357: v.rast.stats: add support for -d flag (densified lines)
trac at osgeo.org
Sat Jul 22 11:47:46 PDT 2017
Reporter: veroandreo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.2
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.rast.stats, v.to.rast
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:3 mlennert]:
> AFAICT this comes from the v.to.rast call. It is harmless, but probably
a bit confusing. You should be able to solve this by adding a type
parameter to v.rast.stats and send that to v.to.rast.
Instead of adding a new type parameter the patch now contains an extra
test to check when to apply -d internally. Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3357#comment:4>
