[GRASS-dev] [GRASS GIS] #3357: v.rast.stats: add support for -d flag (densified lines)
trac at osgeo.org
Mon Jul 24 02:22:05 PDT 2017
Reporter: veroandreo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.2
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.rast.stats, v.to.rast
CPU: Unspecified | Platform: Unspecified
Comment (by veroandreo):
Removing previous patch and applying the second one, I get the following:
v.rast.stats myrailroads raster=elevation column_prefix=elev
method=average -d
Preprocessing input data...
File "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-
gnu/scripts/v.rast.stats", line 312, in <module>
main()
gnu/scripts/v.rast.stats", line 139, in main
from pygrass.vector import VectorTopo
ImportError: No module named pygrass.vector
WARNING: No data base element files found
Here the output of svn diff
[veroandreo at utwks62764 v.rast.stats]$ svn diff
Index: v.rast.stats.py
--- v.rast.stats.py (revision 71311)
+++ v.rast.stats.py (working copy)
@@ -31,6 +31,11 @@
#% key: c
#% description: Continue if upload column(s) already exist
#%end
+#%flag
+#% key: d
+#% label: Create densified lines (default: thin lines)
+#% description: All cells touched by the line will be set, not only those
on the render path
+#%end
#%option G_OPT_V_MAP
#%end
#%option G_OPT_V_FIELD
@@ -131,8 +136,17 @@
grass.message(_("Preprocessing input data..."))
try:
- grass.run_command('v.to.rast', input=vector, layer=layer,
output=rastertmp,
- use='cat', quiet=True)
+ from pygrass.vector import VectorTopo
+ inmap = VectorTopo(vector)
+ inmap.open('r')
+ nlines = inmap.num_primitive_of('lines')
+ # Create densified lines rather than thin lines
+ if flags['d'] and nlines > 0:
+ grass.run_command('v.to.rast', input=vector, layer=layer,
output=rastertmp,
+ use='cat', flags='d', quiet=True)
+ else:
output=rastertmp,
+ use='cat', quiet=True)
except CalledModuleError:
grass.fatal(_("An error occurred while converting vector to
raster"))
Ticket URL: <https://trac.osgeo.org/grass/ticket/3357#comment:5>
