[GRASS-dev] [GRASS GIS] #3357: v.rast.stats: add support for -d flag (densified lines)
trac at osgeo.org
Mon Jul 24 06:19:10 PDT 2017
Reporter: veroandreo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.2
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.rast.stats, v.to.rast
CPU: Unspecified | Platform: Unspecified
Comment (by lucadelu):
Not able to replace the previous diff... here your are the working one
Index: scripts/v.rast.stats/v.rast.stats.py
--- scripts/v.rast.stats/v.rast.stats.py (revision 71311)
+++ scripts/v.rast.stats/v.rast.stats.py (working copy)
@@ -31,6 +31,11 @@
#% key: c
#% description: Continue if upload column(s) already exist
#%end
+#%flag
+#% key: d
+#% label: Create densified lines (default: thin lines)
+#% description: All cells touched by the line will be set, not only those
on the render path
+#%end
#%option G_OPT_V_MAP
#%end
#%option G_OPT_V_FIELD
@@ -131,8 +136,17 @@
grass.message(_("Preprocessing input data..."))
try:
- grass.run_command('v.to.rast', input=vector, layer=layer,
output=rastertmp,
- use='cat', quiet=True)
+ from grass.pygrass.vector import VectorTopo
+ inmap = VectorTopo(vector)
+ inmap.open('r')
+ nlines = inmap.num_primitive_of('line')
+ # Create densified lines rather than thin lines
+ if flags['d'] and nlines > 0:
+ grass.run_command('v.to.rast', input=vector, layer=layer,
output=rastertmp,
+ use='cat', flags='d', quiet=True)
+ else:
output=rastertmp,
+ use='cat', quiet=True)
except CalledModuleError:
grass.fatal(_("An error occurred while converting vector to
raster"))
Now working on testsuite and later, if it works, I will commit the changes
Ticket URL: <https://trac.osgeo.org/grass/ticket/3357#comment:6>
