[GRASS-dev] [GRASS GIS] #3357: v.rast.stats: add support for -d flag (densified lines)
GRASS GIS trac at osgeo.org
Mon Jul 24 06:42:45 PDT 2017
  Reporter:  veroandreo   |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.2.2
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.rast.stats, v.to.rast
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:6 lucadelu]:
 > Not able to replace the previous diff... here your are the working one
 > Index: scripts/v.rast.stats/v.rast.stats.py
 > --- scripts/v.rast.stats/v.rast.stats.py      (revision 71311)
 > +++ scripts/v.rast.stats/v.rast.stats.py      (working copy)
 > @@ -31,6 +31,11 @@
 >  #% key: c
 >  #% description: Continue if upload column(s) already exist
 >  #%end
 > +#%flag
 > +#% key: d
 > +#% label: Create densified lines (default: thin lines)
 > +#% description: All cells touched by the line will be set, not only
 those on the render path
 > +#%end
 >  #%option G_OPT_V_MAP
 >  #%end
 >  #%option G_OPT_V_FIELD
 > @@ -131,8 +136,17 @@
 >      grass.message(_("Preprocessing input data..."))
 >      try:
 > -        grass.run_command('v.to.rast', input=vector, layer=layer,
 output=rastertmp,
 > -                          use='cat', quiet=True)
 > +        from grass.pygrass.vector import VectorTopo
 > +        inmap = VectorTopo(vector)
 > +        inmap.open('r')
 > +        nlines = inmap.num_primitive_of('line')
 don't forget to close inmap.
 simpler alternative
         nlines = grass.vector_info_topo(vector)['lines']
 > +        # Create densified lines rather than thin lines
 > +        if flags['d'] and nlines > 0:
 > +            grass.run_command('v.to.rast', input=vector, layer=layer,
 output=rastertmp,
 > +                              use='cat', flags='d', quiet=True)
 > +        else:
 output=rastertmp,
 > +                              use='cat', quiet=True)
 >      except CalledModuleError:
 >          grass.fatal(_("An error occurred while converting vector to
 raster"))
 > Now working on testsuite and later, if it works, I will commit the
 changes
Ticket URL: <https://trac.osgeo.org/grass/ticket/3357#comment:7>
