[GRASS-dev] [GRASS GIS] #3380: v.what.vect query_column dropdown button doesn't show attribute columns of query_map
trac at osgeo.org
Wed Jul 26 09:17:17 PDT 2017
query_map
Reporter: rorschach | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: 7.2.1
Keywords: v.what.vect | CPU: Unspecified
Platform: Linux |
A pleasant day to everyone.
Does anyone else encounter this problem? When I'm using v.what.vect, the
query_column dropdown button doesn't show the attribute columns of the
vector layer specified by query_map.
It's not too much of an issue since the user can always type the column
names manually but the dropdown button is supposed to be there to allow
the user to select the attribute columns of their query_map.
If anyone knows a fix or wants to fix this, I would highly appreciate it.
By the way, I'm using GRASS 7.2.1 on Xubuntu 16.04.
Thank you.
''Attached is an image for your perusal.''
Ticket URL: <https://trac.osgeo.org/grass/ticket/3380>
