[GRASS-dev] New attempt to update GRASS for Mac
Michael Barton Michael.Barton at asu.edu
Fri Jul 28 11:09:44 PDT 2017
Previously, we needed to set this path to compile GRASS so that it worked with wxPython wrappers for wxWidgets. I will do a new compile without this argument and see what happens.
In any case, I need to be able to make sure that GRASS uses the wxPython that is bundled with it by default to avoid differences in versions and SIP issues.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 28, 2017, at 7:56 AM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
On Thu, Jul 27, 2017 at 11:52 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
> The other issue I'm hitting is that the configure argument to enable wxPython, '-with-wxwidgets=' expects a path to a wx_config file. AFAICT, wxPython 4 does not have such a file. And I can't yet find anything that seems to serve the same function. I can put in a path to the folder/directory where the wxPython 4 files live. While this compiles without error, I don't think it is using wxPython 4.
--with-wxwidgets= is for wxWidgets (C++ library), not wxPython (its Python wrapper), so you don't need to use at all. wxPython must be part of the Python installation you are using.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170728/985423fb/attachment.html>
