[GRASS-dev] New attempt to update GRASS for Mac
Michael Barton
Michael.Barton at asu.edu
Fri Jul 28 12:49:48 PDT 2017
ARGGH!
Set up and activated virtual environment in conda
Ensured that Anaconda Python is default
Ensured that Anaconda wxPython 4 is default
Compiled GRASS trunk in this environment
Launched the app created and...
Launching <wxpython> GUI in the background, please wait...
GRASS 7.3.svn (nc_spm_08_grass7):~ > python
Python 2.7.10 (default, Feb 7 2017, 00:08:15)
[GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import wx
>>> import wxversion
>>> wx.VERSION_STRING
'3.0.2.0'
Using my system Python and system wxPython
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 28, 2017, at 12:09 PM, Michael Barton <michael.barton at asu.edu<mailto:michael.barton at asu.edu>> wrote:
Previously, we needed to set this path to compile GRASS so that it worked with wxPython wrappers for wxWidgets. I will do a new compile without this argument and see what happens.
In any case, I need to be able to make sure that GRASS uses the wxPython that is bundled with it by default to avoid differences in versions and SIP issues.
Michael
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Jul 28, 2017, at 7:56 AM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
On Thu, Jul 27, 2017 at 11:52 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
> The other issue I'm hitting is that the configure argument to enable wxPython, '-with-wxwidgets=' expects a path to a wx_config file. AFAICT, wxPython 4 does not have such a file. And I can't yet find anything that seems to serve the same function. I can put in a path to the folder/directory where the wxPython 4 files live. While this compiles without error, I don't think it is using wxPython 4.
--with-wxwidgets= is for wxWidgets (C++ library), not wxPython (its Python wrapper), so you don't need to use at all. wxPython must be part of the Python installation you are using.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170728/a37ed40f/attachment.html>
