[GRASS-dev] [GRASS-SVN] r70821 - grass/trunk/include/Make
Markus Neteler neteler at osgeo.org
Mon Jun 5 11:37:55 PDT 2017
Hi Māris,
On Wed, May 31, 2017 at 5:25 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello Markus,
> no idea, as it runs just fine on my system and I do not see any easy
> to spot problem with test.c code. You should run it under valgrind /
> gdb or just send me the core file.
> Ah, yes, while at it, include also
> /home/mundialis/software/grass72_svn/dist.x86_64-pc-linux-gnu/demolocation/.grassrc72
> Setting all locale stuff to C should prevent failures when translated
> strings are used or comma is the decimal separator thus it *should* be
> harmless.
indeed it is.
I got into a trap with a gcc compiler flag which collided in an
"interesting" way after having virtualised my workhorse machine at the
same time when I backported the change.
Sorry for the noise, all good.
Markus
