[GRASS-dev] [GRASS GIS] #3331: ctypes: ValueError: invalid literal for int() with base 8: '08420217248550443400745280086994171'
GRASS GIS trac at osgeo.org
Mon Jun 5 22:40:55 PDT 2017
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.2
 Component:  Python       |    Version:  unspecified
Resolution:               |   Keywords:  ctypes, python
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by brunofriedmann):
 We (openSUSE) also see the same error.
 [  115s] make[6]: Entering directory
 '/home/abuild/rpmbuild/BUILD/grass-7.2.1/lib/python/ctypes'
 [  115s] test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-
 gnu
 [  115s] GISRC=/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-
 linux-gnu/demolocation/.grassrc72
 GISBASE=/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-linux-gnu
 PATH="/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/bin:/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/scripts:$PATH"
 PYTHONPATH="/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-linux-
 gnu/etc/python:/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-
 linux-gnu/gui/wxpython:$PYTHONPATH"
 LD_LIBRARY_PATH="/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-
 linux-gnu/bin:/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-
 linux-gnu/scripts:/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-
 linux-gnu/lib:/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-
 linux-gnu/lib:" LC_ALL=C ./ctypesgen.py --cpp "gcc -E
 -I/home/abuild/rpmbuild/BUILD/grass-7.2.1/dist.x86_64-pc-linux-gnu/include
 -D__GLIBC_HAVE_LONG_LONG" -lgrass_datetime.7.2.1
 gnu/include/grass/datetime.h
 gnu/include/grass/defs/datetime.h -o OBJ.x86_64-pc-linux-gnu/date.py
 [  115s] Status: Preprocessing /tmp/tmpSIivMQ.h
 [  115s] Status: gcc -E
 -D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
 "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
 "-D__asm(x)=" "-DCTYPESGEN=1" /tmp/tmpSIivMQ.h
 [  115s] Traceback (most recent call last):
 [  115s]   File "./ctypesgen.py", line 139, in <module>
 [  115s]     descriptions = ctypesgencore.parser.parse(options.headers,
 options)
 [  115s]   File
 "/home/abuild/rpmbuild/BUILD/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/__init__.py",
 line 22, in parse
 [  115s]     parser.parse()
 [  115s]   File
 "/home/abuild/rpmbuild/BUILD/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py",
 line 74, in parse
 [  115s]     ctypesparser.CtypesParser.parse(self, fname, None)
 [  115s]   File
 "/home/abuild/rpmbuild/BUILD/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/cparser.py",
 line 120, in parse
 [  115s]     self.preprocessor_parser.parse(filename)
 [  115s]   File
 "/home/abuild/rpmbuild/BUILD/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/preprocessor.py",
 line 218, in parse
 [  115s]     token = self.lexer.token()
 [  115s]   File
 line 63, in token
 [  115s]     result = lex.Lexer.token(self)
 [  115s]   File
 "/home/abuild/rpmbuild/BUILD/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/lex.py",
 line 355, in token
 [  115s]     newtok = func(tok)
 [  115s]   File
 "/home/abuild/rpmbuild/BUILD/grass-7.2.1/lib/python/ctypes/ctypesgencore/parser/pplexer.py",
 line 262, in t_ANY_int
 [  115s]     g1 = str(long(g1, 8))
 [  115s] ValueError: invalid literal for int() with base 8:
 [  115s] make[6]: *** [Makefile:102: OBJ.x86_64-pc-linux-gnu/date.py]
 Error 1
 [  115s] make[6]: Leaving directory
 [  115s] make[5]: *** [Makefile:81: default] Error 2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3331#comment:2>
