[GRASS-dev] Vector digitizer not available: Reason: cannot import name GV_LINES
Markus Neteler
neteler at osgeo.org
Wed Jun 14 13:16:20 PDT 2017
On Wed, Jun 14, 2017 at 3:36 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Anna Petrášová wrote
>> On Wed, Jun 14, 2017 at 8:20 AM, Helmut Kudrnovsky <
>> hellik@
>> > wrote:
>>> hi
>>> just started:
>>> System Info
>>> GRASS version: 7.3.svn
>>> GRASS SVN revision: r71182M
>>> Build date: 2017-06-13
>>> Build platform: x86_64-w64-mingw32
>>> GDAL: 2.1.3
>>> PROJ.4: 4.9.3
>>> GEOS: 3.5.0
>>> SQLite: 3.17.0
>>> Python: 2.7.5
>>> wxPython: 2.8.12.1
>>> Platform: Windows-8-6.2.9200 (OSGeo4W)
>>> then I get:
>>> "Vector digitizer not available
>>> Note that the wxGUI's vector digitizer is currently disabled
>>> (hopefully this will be fixed soon). Please keep an eye out
>>> for updated versions of GRASS. In the meantime you can use
>>> "v.digit" from the Develop Vector menu."
>>> any idea?
>> This suggests some problem with ctypes. I wonder if
>> https://trac.osgeo.org/grass/changeset/71180
>> is the problem. Do previous builds work?
> tested with
> System Info
> GRASS SVN revision: r71175M
> Build date: 2017-06-12
> GDAL: 2.1.3
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.17.0
> Python: 2.7.5
> wxPython: 2.8.12.1
> it works there. no error message.
So, did you re-add the commented line? And then it works again?
Markus
