[GRASS-dev] Vector digitizer not available: Reason: cannot import name GV_LINES
Helmut Kudrnovsky
hellik at web.de
Wed Jun 14 06:36:43 PDT 2017
Anna Petrášová wrote
> On Wed, Jun 14, 2017 at 8:20 AM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> hi
>> just started:
>> System Info
>> GRASS version: 7.3.svn
>> GRASS SVN revision: r71182M
>> Build date: 2017-06-13
>> Build platform: x86_64-w64-mingw32
>> GDAL: 2.1.3
>> PROJ.4: 4.9.3
>> GEOS: 3.5.0
>> SQLite: 3.17.0
>> Python: 2.7.5
>> wxPython: 2.8.12.1
>> Platform: Windows-8-6.2.9200 (OSGeo4W)
>> then I get:
>> "Vector digitizer not available
>> Note that the wxGUI's vector digitizer is currently disabled
>> (hopefully this will be fixed soon). Please keep an eye out
>> for updated versions of GRASS. In the meantime you can use
>> "v.digit" from the Develop Vector menu."
>> any idea?
> This suggests some problem with ctypes. I wonder if
> https://trac.osgeo.org/grass/changeset/71180
> is the problem. Do previous builds work?
tested with
System Info
GRASS SVN revision: r71175M
Build date: 2017-06-12
GDAL: 2.1.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
it works there. no error message.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Vector-digitizer-not-available-Reason-cannot-import-name-GV-LINES-tp5324169p5324192.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
