[GRASS-dev] Vector digitizer not available: Reason: cannot import name GV_LINES
Anna Petrášová kratochanna at gmail.com
Wed Jun 14 05:53:25 PDT 2017
On Wed, Jun 14, 2017 at 8:20 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi
> just started:
> System Info
> GRASS version: 7.3.svn
> GRASS SVN revision: r71182M
> Build date: 2017-06-13
> Build platform: x86_64-w64-mingw32
> GDAL: 2.1.3
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.17.0
> Python: 2.7.5
> wxPython: 2.8.12.1
> Platform: Windows-8-6.2.9200 (OSGeo4W)
> then I get:
> "Vector digitizer not available
> Note that the wxGUI's vector digitizer is currently disabled
> (hopefully this will be fixed soon). Please keep an eye out
> for updated versions of GRASS. In the meantime you can use
> "v.digit" from the Develop Vector menu."
> any idea?
This suggests some problem with ctypes. I wonder if
https://trac.osgeo.org/grass/changeset/71180
is the problem. Do previous builds work?
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Vector-digitizer-not-available-Reason-cannot-import-name-GV-LINES-tp5324169.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
