[GRASS-dev] Vector digitizer not available: Reason: cannot import name GV_LINES
Helmut Kudrnovsky
hellik at web.de
Wed Jun 14 05:20:20 PDT 2017
hi
just started:
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r71182M
Build date: 2017-06-13
Build platform: x86_64-w64-mingw32
GDAL: 2.1.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
then I get:
"Vector digitizer not available
Note that the wxGUI's vector digitizer is currently disabled
(hopefully this will be fixed soon). Please keep an eye out
for updated versions of GRASS. In the meantime you can use
"v.digit" from the Develop Vector menu."
any idea?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Vector-digitizer-not-available-Reason-cannot-import-name-GV-LINES-tp5324169.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
