[GRASS-dev] Managing the translations with Transifex
Luca Delucchi
lucadeluge at gmail.com
Tue Jun 27 05:58:26 PDT 2017
On 27 June 2017 at 12:06, Markus Neteler <neteler at osgeo.org> wrote:
>> - I don't know what the issue concerning empty translations is about.
> The current (new) flow is [Luca, correct me if I am wrong]:
> 1. messages are extracted from the source code in trunk with the
> common gettext mechanism (done by the transifex portal)
> 2. folks translate in the transifex portal
> 3. I or any other developer sometimes merges the translations back
> using this script:
> grass-addons/tools/transifex_merge.sh
> 4. start from 1.
correct
> Issue:
> - how to get messages intro relbranch72
probably msgmerge could be enough
> - can step 3 be done with a cronjob? which frequency?
yes it could be done using a cronjob, maybe daily updates could be
fine, I don't have an answer if something went wrong.
In other case I could do the monkey job to update the languages...
> Markus
ciao
Luca
www.lucadelu.org
