[GRASS-dev] Managing the translations with Transifex
Markus Neteler
neteler at osgeo.org
Tue Jun 27 03:06:48 PDT 2017
On Tue, Jun 27, 2017 at 9:08 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 26/06/17 20:37, Markus Neteler wrote:
> Sorry, Markus, but on my side, I'm just currently completely ignorant about
> translation procedures and issues in GRASS. I didn't even know we had a
> solution via transifex (which is great BTW !)...
NP, it was loosely discussed here and there in the list.
> With this ignorance in mind, I would say:
> - Activate the cron job. If it fails, we'll repair.
Yep - do-ocracy matters.
> - I don't know what the issue concerning empty translations is about.
The current (new) flow is [Luca, correct me if I am wrong]:
1. messages are extracted from the source code in trunk with the
common gettext mechanism (done by the transifex portal)
2. folks translate in the transifex portal
3. I or any other developer sometimes merges the translations back
using this script:
grass-addons/tools/transifex_merge.sh
4. start from 1.
Issue:
- how to get messages intro relbranch72
- can step 3 be done with a cronjob? which frequency?
> - I don't know what the issue concerning the choice between msgmerge and
> transifex_merge.sh, and the backport, is about. I don't even know where to
> find these files.
In a nutshell (see previous discussions in the archive):
The transifex_merge.sh is based on a script I wrote long time back and
enhanced by Luca to deal with the transifex part.
> So, in short: if you want feedback on such issues from all of us a bit more
> explanation of the issues might be necessary.
Well, it has been discussion, but with too much time in between.
I just want to avoid to break stuff on the transifex portal.
> And from my ignorance a question: why don't we "just" move all translation
> to transifex and so avoid the need for merges between translations from
> different sources.
This is how it is! But of course we must feed our .po files in the
source code somehow.
How this clarifies it for you.
Markus
