[GRASS-dev] t.register without input stds
Veronica Andreo
veroandreo at gmail.com
Thu Mar 2 08:45:57 PST 2017
Hi there,
El 2 mar. 2017 3:08 p. m., "Luca Delucchi" <lucadeluge at gmail.com> escribió:
> On 2 March 2017 at 11:15, Veronica Andreo <veroandreo at gmail.com> wrote:
> > Hola Lu,
> Hey,
> > Yes, that was a discussion in the user list until a couple of days ago.
> > Check this thread:
> > https://lists.osgeo.org/pipermail/grass-user/2017-February/076022.html
> > I sent a diff with an explanation for t.register manual page and Soeren
> said
> > he would apply it this weekend with some other modifications.
> thanks for pointing me to the thread, so if the behavior is correct I
> think we need to have several modules to register maps:
> - t.register.maps used to register maps in temporal framework
> - t.register.strds register maps in a strds
> - t.register.stvds register maps in a stvds
> - t.register.str3ds register maps in a str3ds
> what do you think? Is this solution to much complicated for final users?
Mmm, dunno honestly... I prefer the present form, but might be because I'm
used to it already...
I would say that a good documentation of the behaviour of t.register using
input or not is the most important, and that's on its way... otherwise, if
you have t.register.maps and t.register.stxds as suggested, it might become
even more confusing for users... should they then always have to use both
modules? And on top of that, it seems to me quite repetitive to have 4
modules to do what only one is able to do just by changing 2 options (i.e.:
input and type). But that's my opinion only :P
Baci,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170302/cc89501a/attachment.html>
