[GRASS-dev] RGB colored and Transparent areas in one vector map
Nikos Alexandris
nik at nikosalexandris.net
Mon Mar 6 03:44:49 PST 2017
Dear all,
I have an rgb_column with RGBs for a vector map. For some areas, I would
like to have no color, as in trasparent.
If I am not wrong, we can't do that, ie define "nv" as we can do in
color rules for a raster map.
Can we?
I did not test for removing the centroids, from the areas which I want
transparency. Then again, this isn't the right answer I feel.
Thanks, Nikos
