[GRASS-dev] RGB colored and Transparent areas in one vector map
Moritz Lennert
mlennert at club.worldonline.be
Mon Mar 6 04:40:01 PST 2017
On 06/03/17 12:44, Nikos Alexandris wrote:
> Dear all,
> I have an rgb_column with RGBs for a vector map. For some areas, I would
> like to have no color, as in trasparent.
> If I am not wrong, we can't do that, ie define "nv" as we can do in
> color rules for a raster map.
> Can we?
I don't think so,
The easiest workaround I see is to set your rgb_colum to NULL where you
want transparency (or to create a separate transparency column) and
display your map twice:
d.vect MyMap rgb_column=MyCol where="MyCol IS NOT NULL"
or
d.vect MyMap rgb_column=MyCol where="transparency = 0"
d.vect MyMap fcol=none where="MyCol IS NULL"
or
d.vect MyMap fcol=none where="transparency = 1"
Moritz
