[GRASS-dev] r.in.gdal and xargs
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Mar 6 06:02:14 PST 2017
Thanks Vincent for your swift reply.
In principle the pipe to xargs works, as 99% of the data is imported properly. And also in the case were I get roors, the command is started properly...
Thus, I suspect that r.in.gdal can have issues when run in parallel; or the creation of temp files, in particular the creation of the .tmp/HOST directory within the mapset...
Cheers
Stefan
