[GRASS-dev] r.in.gdal and xargs
Vincent Bain
bain at toraval.fr
Mon Mar 6 06:07:15 PST 2017
Yes, perhaps something to do with r.in.gdal temp files handling.
And what if you try to reduce P value ?
well, of course it will slow down the bulk import...
Le lundi 06 mars 2017 à 14:02 +0000, Blumentrath, Stefan a écrit :
> Thanks Vincent for your swift reply.
> In principle the pipe to xargs works, as 99% of the data is imported properly. And also in the case were I get roors, the command is started properly...
> Thus, I suspect that r.in.gdal can have issues when run in parallel; or the creation of temp files, in particular the creation of the .tmp/HOST directory within the mapset...
> Cheers
> Stefan
