[GRASS-dev] r.in.gdal and xargs
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Mar 6 06:57:14 PST 2017
I can parallelize on a higher level, so i can set P to 1 here.
If it is a bug I can open a ticket...
________________________________________
Von: Vincent Bain [bain at toraval.fr]
Gesendet: Montag, 6. März 2017 15:07
An: Blumentrath, Stefan
Cc: GRASS developers list (grass-dev at lists.osgeo.org)
Betreff: Re: [GRASS-dev] r.in.gdal and xargs
Yes, perhaps something to do with r.in.gdal temp files handling.
And what if you try to reduce P value ?
well, of course it will slow down the bulk import...
Le lundi 06 mars 2017 à 14:02 +0000, Blumentrath, Stefan a écrit :
> Thanks Vincent for your swift reply.
> In principle the pipe to xargs works, as 99% of the data is imported properly. And also in the case were I get roors, the command is started properly...
> Thus, I suspect that r.in.gdal can have issues when run in parallel; or the creation of temp files, in particular the creation of the .tmp/HOST directory within the mapset...
> Cheers
> Stefan
