[GRASS-dev] GSoC 2017 - Generalized GUI code for Qt-based GUI
Vaclav Petras wenzeslaus at gmail.com
Wed Mar 8 13:37:23 PST 2017
On Wed, Mar 8, 2017 at 2:21 AM, Ondrej Svoboda <svoboond at gmail.com> wrote:
> A topic I am most interested in is Generalized GUI code for Qt-based GUI
> [1].
It would be good if you fork & clone the repo from last year [3] and make
it work on your computer. It should be easy to find few things which you
can fix or improve in the application period. Alternatively, since you have
experience with QGIS plugins, you can turn that code into a QGIS plugin
instead of fixing and improving.
Also, go ahead and start writing down what would be the particular things
you would implement during GSoC. The topic is very broad and the above
steps will help you narrow it down for GSoC.
[3] https://github.com/pesekon2/GRASS-Qt-based-GUI
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170308/71ae0675/attachment.html>
