[GRASS-dev] custom CRS
Paulo van Breugel p.vanbreugel at gmail.com
Sat Mar 18 08:30:05 PDT 2017
On 18-03-17 13:52, Helmut Kudrnovsky wrote:
>> Or can / should I
>> add this to the datum information files in $GISBASE/etc/proj/ogr_csv?
> quite interesting as I don't have here $GISBASE/etc/proj/ogr_csv
Same here, sorry, copied that line from the g.proj help file. Should
probably be corrected in the g.proj help file (in the description
section in the part about the epsg. But the path may differ depending on
the OS I guess, so not sure what to change it to.
> from a fresh svn up and compilation
> nada:~/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/proj$ ls -l
> insgesamt 228
> -rw-r--r-- 1  5725 Mär 12 22:33 datum.table
> -rw-r--r-- 1  7556 Mär 12 22:33 datumtransform.table
> -rw-r--r-- 1 1465 Mär 12 22:34 desc.table
> -rw-r--r-- 1  5969 Mär 12 22:33 ellipse.table
> -rw-r--r-- 1 8292 Mär 12 22:33 ellipse.table.solar.system
> -rw-r--r-- 1 120559 Mär 12 22:33 FIPS.code
> -rw-r--r-- 1 7939 Mär 12 22:34 parms.table
> -rw-r--r-- 1 2950 Mär 12 22:33 projections
> -rw-r--r-- 1 25112 Mär 12 22:33 state27
> -rw-r--r-- 1 20617 Mär 12 22:33 state83
> -rw-r--r-- 1 464 Mär 12 22:34 units.table
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/custom-CRS-tp5312992p5313012.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
