[GRASS-dev] custom CRS
Paulo van Breugel p.vanbreugel at gmail.com
Sat Mar 18 08:51:19 PDT 2017
On 18-03-17 16:30, Paulo van Breugel wrote:
> On 18-03-17 13:52, Helmut Kudrnovsky wrote:
>>> Or can / should I
>>> add this to the datum information files in $GISBASE/etc/proj/ogr_csv?
>> quite interesting as I don't have here $GISBASE/etc/proj/ogr_csv
> Same here, sorry, copied that line from the g.proj help file. Should
> probably be corrected in the g.proj help file (in the description
> section in the part about the epsg. But the path may differ depending
> on the OS I guess, so not sure what to change it to.
OK, I am confusing things: I have the datumtransform.table and the
datum.table in two folders:
/usr/local/grass7/grass-7.3.svn/etc/proj/
/usr/local/share/gdal/grass/etc/  (installed with grass-gdal plugin?)
The other files listed below are only in the folder
/usr/local/grass7/grass-7.3.svn/etc/proj/.  So the help file is correct
in my case.
>> from a fresh svn up and compilation
>> nada:~/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/proj$ ls -l
>> insgesamt 228
>> -rw-r--r-- 1  5725 Mär 12 22:33 datum.table
>> -rw-r--r-- 1  7556 Mär 12 22:33 datumtransform.table
>> -rw-r--r-- 1 1465 Mär 12 22:34 desc.table
>> -rw-r--r-- 1  5969 Mär 12 22:33 ellipse.table
>> -rw-r--r-- 1 8292 Mär 12 22:33 ellipse.table.solar.system
>> -rw-r--r-- 1 120559 Mär 12 22:33 FIPS.code
>> -rw-r--r-- 1 7939 Mär 12 22:34 parms.table
>> -rw-r--r-- 1 2950 Mär 12 22:33 projections
>> -rw-r--r-- 1 25112 Mär 12 22:33 state27
>> -rw-r--r-- 1 20617 Mär 12 22:33 state83
>> -rw-r--r-- 1 464 Mär 12 22:34 units.table
>> best regards
>> Helmut
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/custom-CRS-tp5312992p5313012.html
>> Sent from the Grass - Dev mailing list archive at Nabble.com.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
