[GRASS-dev] Creating / reading in random sample of raster values in Python script
Paulo van Breugel p.vanbreugel at gmail.com
Sat Mar 25 12:44:05 PDT 2017
On 25 March 2017 20:21:18 Luca Delucchi <lucadeluge at gmail.com> wrote:
> Il 25/mar/2017 20:07, "Paulo van Breugel" <p.vanbreugel at gmail.com> ha
> scritto:
> Hi,
> Hi,
> For a script I am working on, I am looking for a way to select a X number
> of raster cells and their values into a numpy array. I can create a layer
> with r.random, and read in that layer into a numpy array, but I rather
> avoid having to read in the whole raster layer. I can also from within the
> script run r.random  to generate a raster layer, r.stats to export the
> resulting raster layer as a text file (with n flag), and than read in the
> text file in Python. But I wonder if there is not a more direct way to
> accomplish this..
> You can read col and row from GRASS Region and use random python function
> to calculate random x and y and later query a pygrass raster object
Thanks. And what if I have a mask or null values in the target raster.
> Cheers,
> Paulo
> Cheers
> Luca
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170325/cf83149e/attachment.html>
