[GRASS-dev] Creating / reading in random sample of raster values in Python script
Laurent C. lrntct at gmail.com
Sat Mar 25 15:11:27 PDT 2017
Hello,
If you need a fixed number of points, you might do a while loop that
randomly generate coordinates then add the point only if the array is not
null at those coordinates.
Laurent
On 25 Mar 2017 13:55, "Paulo van Breugel" <p.vanbreugel at gmail.com> wrote:
> On 25 March 2017 20:21:18 Luca Delucchi <lucadeluge at gmail.com> wrote:
> > Il 25/mar/2017 20:07, "Paulo van Breugel" <p.vanbreugel at gmail.com> ha
> > scritto:
> > Hi,
> > Hi,
> > For a script I am working on, I am looking for a way to select a X number
> > of raster cells and their values into a numpy array. I can create a layer
> > with r.random, and read in that layer into a numpy array, but I rather
> > avoid having to read in the whole raster layer. I can also from within
> the
> > script run r.random  to generate a raster layer, r.stats to export the
> > resulting raster layer as a text file (with n flag), and than read in the
> > text file in Python. But I wonder if there is not a more direct way to
> > accomplish this..
> > You can read col and row from GRASS Region and use random python function
> > to calculate random x and y and later query a pygrass raster object
> Thanks. And what if I have a mask or null values in the target raster.
> > Cheers,
> > Paulo
> > Cheers
> > Luca
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170325/d404d874/attachment-0001.html>
