[GRASS-dev] Creating / reading in random sample of raster values in Python script
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Mar 26 01:58:15 PDT 2017
On 25-03-17 23:11, Laurent C. wrote:
> Hello,
> If you need a fixed number of points, you might do a while loop that
> randomly generate coordinates then add the point only if the array is
> not null at those coordinates.
Thanks, I'll give that a try. Will also see how this compares with using
r.random/r.what in terms of speed.
> Laurent
> On 25 Mar 2017 13:55, "Paulo van Breugel" <p.vanbreugel at gmail.com
> <mailto:p.vanbreugel at gmail.com>> wrote:
> On 25 March 2017 20:21:18 Luca Delucchi <lucadeluge at gmail.com
> <mailto:lucadeluge at gmail.com>> wrote:
> > Il 25/mar/2017 20:07, "Paulo van Breugel"
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> ha
> > scritto:
> > Hi,
> > Hi,
> > For a script I am working on, I am looking for a way to select a
> X number
> > of raster cells and their values into a numpy array. I can
> create a layer
> > with r.random, and read in that layer into a numpy array, but I
> rather
> > avoid having to read in the whole raster layer. I can also from
> within the
> > script run r.random to generate a raster layer, r.stats to
> export the
> > resulting raster layer as a text file (with n flag), and than
> read in the
> > text file in Python. But I wonder if there is not a more direct
> way to
> > accomplish this..
> > You can read col and row from GRASS Region and use random python
> function
> > to calculate random x and y and later query a pygrass raster object
> Thanks. And what if I have a mask or null values in the target raster.
> > Cheers,
> > Paulo
> > Cheers
> > Luca
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-dev
> <https://lists.osgeo.org/mailman/listinfo/grass-dev>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170326/d1ad1ee2/attachment.html>
