[GRASS-dev] new addon: v.what.rast.multi
Pierre Roudier
pierre.roudier at gmail.com
Wed May 10 14:49:48 PDT 2017
Thanks Luca, that would be a good idea indeed!
Any pointers to implement this? I'm unfamiliar with parallel processing in
Pygrass.
Cheers,
P
On 9 May 2017 at 18:36, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 8 May 2017 at 07:16, Pierre Roudier <pierre.roudier at gmail.com> wrote:
> > Hi all,
> Hi,
> > FYI I just submitted my (first!) GRASS add-on, called v.what.rast.multi
> [0].
> > It is a super simple Python wrapper around v.what.rast, and allows to
> query
> > a suite of rasters in one go:
> thanks, it is useful
> to improve a little bit, you add multiprocessing to the module, for
> example a process for each raster
> > Cheers,
> > Pierre
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170511/3e320967/attachment.html>
