[GRASS-dev] new addon: v.what.rast.multi
Pierre Roudier pierre.roudier at gmail.com
Wed May 10 14:54:06 PDT 2017
Hi Paulo,
fl is used to store flags passed to the command.
There was a typo in my code, and Moritz was kind enough to commit a
corrected version of the add-on (thanks Moritz!),
Would be more than happy to merge both addons, they do look similar enough
to be merged.
Cheers,
P
On 9 May 2017 at 19:30, Paulo van Breugel <p.vanbreugel at gmail.com> wrote:
> Hi Pierre,
> I have one question about the code. In lines 126-130 you create an object
> 'fl', which you subsequently do not seem to use. Perhaps in line 150 it
> should be flags=fl ?
> Something else, last year I wrote an addon r.what.rastlabel (
> https://github.com/ecodiv/GRASS-scripts/tree/master/v.what.rastlabel)
> which can be used to (multiple) raster values and labels. Optionally, it
> can also upload raster values only, like your addon (that part uses the
> same approach you use). I have not yet added it to the grass addon
> repository. I might do that later, at which point we can also see if it
> makes sense to merge the two.
> Cheers,
> Paulo
> On 5/9/17 8:36 AM, Luca Delucchi wrote:
>> On 8 May 2017 at 07:16, Pierre Roudier <pierre.roudier at gmail.com> wrote:
>>> Hi all,
>>> Hi,
>> FYI I just submitted my (first!) GRASS add-on, called v.what.rast.multi
>>> [0].
>>> It is a super simple Python wrapper around v.what.rast, and allows to
>>> query
>>> a suite of rasters in one go:
>>> thanks, it is useful
>> to improve a little bit, you add multiprocessing to the module, for
>> example a process for each raster
> Interesting, could help to speed up with large point data layers.
>> Cheers,
>>> Pierre
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170511/5043e8ca/attachment.html>
