[GRASS-dev] v.surf.bspline with sparse_input - get interpolated values in attribute table
Paulo van Breugel
p.vanbreugel at gmail.com
Sat May 13 13:42:50 PDT 2017
Hi, when using v.surf.bspline with sparse vector map points
(/sparse_input/) the output vector map is a 3D vector point map with the
interpolated values as z-values. However, I want to get the interpolated
values as values in a column of the attribute table. Any idea how to do
this?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170513/c3b74a46/attachment.html>
