[GRASS-dev] v.surf.bspline with sparse_input - get interpolated values in attribute table
Markus Neteler
neteler at osgeo.org
Sun May 14 08:04:28 PDT 2017
Hi
On May 13, 2017 10:42 PM, "Paulo van Breugel" <p.vanbreugel at gmail.com>
wrote:
> Hi, when using v.surf.bspline with sparse vector map points
(sparse_input) the output vector map is a 3D vector point map with the
interpolated values as z-values. However, I want to get the interpolated
values as values in a column of the attribute table. Any idea how to do
this?
You can use v.to.db for this task:
https://grass.osgeo.org/grass72/manuals/v.to.db.html#examples
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170514/71e3fd3f/attachment.html>
