[GRASS-dev] PostGIS layer import
Markus Metz
markus.metz.giswork at gmail.com
Wed May 17 06:03:15 PDT 2017
On Wed, May 17, 2017 at 9:31 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Hi,
> I know there have been discussions on this before, but I would like to
come back to the question of how to handle imports of layers from PostGIS
databases. Possibly there are some elements I still don't really
understand, so I'm launching this debate here, instead of as a bug report.
> In short: I would like to plead for v.in.ogr to support exactly the same
syntax as ogr.
> Example:
> ogrinfo "PG:host=myhost user=theuser password=thepassword
dbname=thedatabase" theschema.thetable -so
> gives me the correct information about a table and
> ogr2ogr myshapefile.shp "PG:host=myhost user=theuser password=thepassword
> gives me a shapefile corresponding to the content of the table.
> I would, therefore, expect to just be able to do this:
> v.in.ogr "PG:host=myhost user=theuser password=thepassword
dbname=thedatabase" layer=theschema.thetable out=mygrassmap
I agree
> In GRASS 7.0 this works. According to the trunk man page, this should
also work (unless the example given (v.in.ogr input="PG:host=localhost
dbname=postgis user=postgres" layer=polymap output=polygons
type=boundary,centroid) is only valid for localhost connections.
> However, I get the fatal error
> "the database 'thedatabase' does not exist".
> In order to get my layer, I have to jump through a series of hoops:
> db.connect driver=pg database=thedatabase schema=theschema
> db.login driver=pg database=thedatabase host=myhost user=theuser
> v.in.ogr input="PG:dbname=thedatabase" layer=theschema.thetable
out=mygrassmap
> Only providing layer=thetable does not seem to work, even though the
schema was already defined using db.connect.
> Besides being overly complicated (as I said, maybe I missed a simpler
way), this actually raises two very serious problems:
> - As I changed the db.connect settings to read a database, all future
writing of attributes will now happen using these settings, which is not at
all what I want.
> - If theuser only has 'select', but not 'create table' rights in the
database and schema, then the v.in.ogr call fails because it cannot write
the table (since it tries to write it to the PostGIS database because of
the db.connect settings).
It seems that v.in.ogr is confusing input and output, or it is unfinished
work for customized PostGIS import not using OGR. I have effectively
deactivated the new get_datasource_name() fn in trunk r71093. v.in.ogr
should now work again with OGR syntax, and there is no need to change the
GRASS db connection settings.
Markus M
> I understand that there are many different situations in databases and
that it is difficult to handle them all, but (again: unless I'm completely
misunderstanding things) the current handling just seems not only overly
complicated, but actually with serious consequences and errors.
> And I think we should not move away from ogr in v.in.ogr.
> In addition, in the GUI import wizard, after having set db.login and
being able to see the available tables with 'v.in.ogr -l', the GUI cannot
list these same tables because it seems to attempt to connect to the
database 'template1' to which the defined user does not have access rights.
> Finally, db.login does not allow erasing existing settings, but the GUI
takes its information from the login file when determining where to connect
when "database" is chosen in the import wizard. One has to manually erase
the file (or relevant lines in the file).
> Maybe a v.in.postgis handling special access needs might be a solution,
leaving v.in.ogr as a real frontend to ogr with exact same behaviour as ogr
> Please let me know if I just completely misunderstand the functioning of
v.in.ogr for PostGIS layers at this stage...
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170517/98226ac9/attachment.html>
