[GRASS-dev] PostGIS layer import
Martin Landa
landa.martin at gmail.com
Wed May 17 06:11:03 PDT 2017
2017-05-17 15:03 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
> It seems that v.in.ogr is confusing input and output, or it is unfinished
> work for customized PostGIS import not using OGR. I have effectively
> deactivated the new get_datasource_name() fn in trunk r71093. v.in.ogr
> should now work again with OGR syntax, and there is no need to change the
> GRASS db connection settings.
I will be ale to take a look on Friday. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
