[GRASS-dev] [GRASS GIS] #3350: wxGUI: map decorations are not removed when creating new workspace (Ctrl-N)
trac at osgeo.org
Sat May 20 05:41:54 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: wxGUI | Version: svn-trunk
Keywords: wxGUI display decorations | CPU: Unspecified
Platform: Unspecified |
Map decorations are not remove from a map display when one pushes the
button to create a new workspace (Ctrl-N).
IMHO, creating a new workspace means starting from scratch and all
decorations should be removed. In the current state, the user has to
manually remove each of the decorations.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3350>
