[GRASS-dev] [GRASS GIS] #3349: v.import: add 'where' parameter
GRASS GIS trac at osgeo.org
Mon May 22 13:02:38 PDT 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Vector       |    Version:  unspecified
Resolution:               |   Keywords:  v.import where
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:5 mmetz]:
 > Replying to [comment:4 mlennert]:
 > > If the wizard calls the *.import modules, then I think it would be
 better to have as second entry a call to the original v.in.ogr/r.in.gdal
 module GUIs in the menu, instead of the v.import GUI which does not bring
 much added value in comparison to the wizard...
 > > This would allow to increase the visibility of the original modules
 and their additional options.
 > Sounds reasonable: v.import + GUI wizard for quick and dirty import,
 v.in.ogr + generic UI for full-featured import, accordingly for raster
 import.
 The menu entries have been changed in trunk r71108. The [r|v].import
 modules are now labelled as "Simplified [raster|vector] import with
 reprojection" and use the customized GUI interface. r.in.gdal and v.in.ogr
 use their generic UI interface and are in the wxGUI menu labelled as
 "Import of common [raster|vector] formats".
 wxGUI developers, please review these changes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3349#comment:6>
