[GRASS-dev] Building GRASS dev - editing ld.so.conf
Paul Schrum paul.schrum at gmail.com
Mon May 22 15:14:21 PDT 2017
Thank you Moritz.
Since I posted my original question, I have made some progress.  It is
putting the grass executable in
/usr/local/src/grass7_trunk/bin.x86_64-pc-linux-gnu
I was able to run this and run a module to verify that it looks right.
Thanks a lot for your help (and also to Vashek, who helped me in direct
emails.)
I will have more questions, but I will put those in other threads.
- Paul
On Tue, May 16, 2017 at 12:18 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 16/05/17 17:58, Paul Schrum wrote:
>> I am attempting to build GRASS on my machine and I suppose I am having
>> trouble.  I am so bewildered by all of this I can't actually be sure.  I
>> am posting to request help.  Here is my situation:
>> I am new to GRASS development, and I am working on GSoC on integrating
>> PDAL interoperability.   I have not yet set up my project's wiki page or
>> I would link it in this sentence.
>> I am running OSGeo-live on Oracle Virtual Box with my base OS being
>> Windows 8.1.
>> My mentor, Vashek Petras, directed me to start here:
>> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies
>> <https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies
>> and work through the build procedure.  On that page, I am at the point
>> which states,
>> ensure that |/usr/local/lib| is added to |/etc/ld.so.conf| and ...
>> Well I have not created /usr/local/lib, so will it create it if it is
>> not present?  But more importantly, what is /etc/ls.so.conf.  I feel I
>> need to understand what role this file plays before I start modifying
>> it.  Currently it contains one single line:
>> include /etc/ld.so.conf.d/*.conf
>> Also, I created a different dev path than /usr/local.  It is
>> /home/user/Desktop/ALL/SourceModules/cpp
>> and the proj directory resides there.  Should I create /usr/local/lib
>> anyway?
> If you skip the install command, you can also skip all this.
> Just run grass directly from your build directory in which after
> compilation you should have a bin/ directory (containing the GRASS GIS
> startup script) and a dist.*/ directory containing all the rest.
> Just call the binary in the bin/ directory to launch GRASS.
> /usr/local/bin & /usr/local/lib is where the GRASS GIS files are installed
> by default if you run "make install".
> ld.so.conf is a file that contains the paths to libraries that programs
> might need. By adding /usr/local/lib to that file and running ldconfig (as
> root), you add all paths in that file (and in the files in
> /etc/ld.so.conf.d/) to the path where the system looks for libraries by
> default.
> But if you run GRASS directly from the build directory, this is not
> necessary.
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170522/3fdb2cfc/attachment.html>
