[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Helmut Kudrnovsky hellik at web.de
Tue May 23 08:44:57 PDT 2017
Paul Schrum wrote
> I started off trying to build it in a directory under my home directory
> using the instructions here
> <https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies>,
> but I could not get it to build.  The only part of those instructions that
> I was not following were the path.  So I started using the paths indicated
> in those instructions and then it would build.  That is why my copy of the
> source is where it is.
> Based on yall's comments, I now think it was something other than the path
> where I was storing the source code, but I have no idea what.
please post here your steps and error (?)/warning(?) messages of compiling.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321504.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
