[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Paul Schrum
paul.schrum at gmail.com
Wed May 24 10:52:25 PDT 2017
user at osgeolive:~/ALL/SourceModules/cpp/grass7_trunk$ CFLAGS="-O2 -Wall"
LDFLAGS="-s" ./configure --enable-largefile=yes --with-nls --with-cxx
--with-readline --with-pthread --with-proj-share=/usr/local/share/proj/
--with-geos=/usr/local/bin/geos-config --with-wxwidgets --with-cairo
--with-opengl-libs=/usr/include/GL --with-freetype=yes
--with-freetype-includes="/usr/include/freetype2/" --with-postgres=yes
--with-postgres-includes="/usr/include/postgresql" --with-sqlite=yes
--with-mysql=yes --with-mysql-includes="/usr/include/mysql" --with-odbc=no
--with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
Sorry I didn't post the whole thing. It is the same as what is on the
go-by webpage, "GRASS GIS 7 example configuration"
On Wed, May 24, 2017 at 1:40 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Wed, May 24, 2017 at 1:28 PM, Paul Schrum <paul.schrum at gmail.com>
> wrote:
> > Going by
> > https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
> and
> > focusing on GRASS GIS 7 trunk:
> > 1. Last week I did
> > svn co https://svn.osgeo.org/grass/grass/trunk grass7_trunk
> > On a directory under my ownership.
> > 2. Today in that same directory I ran
> > svn up
> > 3. I ran the large statement which begins with
> > CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
> > Here is where the problem is. It seems to go into an infinite loop.*
> The backslash there means that the command continues on the next line,
> you should copy the entire command.
> This is my configure command for example:
> CFLAGS="-ggdb -O0 -Werror-implicit-function-declaration -Wall"
> ./configure \
> --enable-largefile=yes \
> --with-nls \
> --with-cxx \
> --with-readline \
> --with-pthread \
> --with-proj-share=/usr/share/proj/ \
> --with-geos=/usr/local/bin/geos-config \
> --with-wxwidgets \
> --with-cairo \
> --with-opengl-libs=/usr/include/GL \
> --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
> --with-postgres=yes --with-postgres-includes="/usr/include/postgresql" \
> --with-sqlite=yes \
> --with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
> --with-odbc=no \
> --with-netcdf \
> --with-lapack \
> --with-blas \
> --with-omp \
> > Also note that when I run it from /usr/local/src/grass7_trunk -- where I
> was
> > running it when I started this thread -- it succeeded. It did not go
> into
> > the infinite loop.
> > * When the process starts, the first few lines read:
> > ./configure: 229: ./configure: Cannot fork
> > ./configure: 300: ./configure: Cannot fork
> > There is a lot more I could send but have not, including the last lines
> > before it restarts at the top of the loop.
> > Please let me know what more information to five you or what changes I
> > should make.
> > - Paul
> > On Tue, May 23, 2017 at 11:44 AM, Helmut Kudrnovsky <hellik at web.de>
> wrote:
> >> Paul Schrum wrote
> >> > I started off trying to build it in a directory under my home
> directory
> >> > using the instructions here
> >> > <https://grasswiki.osgeo.org/wiki/Compile_and_Install_
> Ubuntu#Dependencies>,
> >> > but I could not get it to build. The only part of those instructions
> >> > that
> >> > I was not following were the path. So I started using the paths
> >> > indicated
> >> > in those instructions and then it would build. That is why my copy of
> >> > the
> >> > source is where it is.
> >> > Based on yall's comments, I now think it was something other than the
> >> > path
> >> > where I was storing the source code, but I have no idea what.
> >> please post here your steps and error (?)/warning(?) messages of
> >> compiling.
> >> best regards
> >> Helmut
> >> View this message in context:
> >> http://osgeo-org.1560.x6.nabble.com/Gaining-write-
> privileges-to-usr-local-and-subdirectories-tp5321487p5321504.html
> >> Sent from the Grass - Dev mailing list archive at Nabble.com.
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170524/fa42e7bf/attachment.html>
