[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Anna Petrášová kratochanna at gmail.com
Wed May 24 10:40:13 PDT 2017
On Wed, May 24, 2017 at 1:28 PM, Paul Schrum <paul.schrum at gmail.com> wrote:
> Going by
> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS and
> focusing on GRASS GIS 7 trunk:
> 1. Last week I did
> svn co https://svn.osgeo.org/grass/grass/trunk grass7_trunk
> On a directory under my ownership.
> 2.  Today in that same directory I ran
> svn up
> 3. I ran the large statement which begins with
> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
> Here is where the problem is.  It seems to go into an infinite loop.*
The backslash there means that the command continues on the next line,
you should copy the entire command.
This is my configure command for example:
CFLAGS="-ggdb -O0 -Werror-implicit-function-declaration -Wall" ./configure \
--enable-largefile=yes \
--with-nls \
--with-cxx \
--with-readline \
--with-pthread \
--with-proj-share=/usr/share/proj/ \
--with-geos=/usr/local/bin/geos-config \
--with-wxwidgets \
--with-cairo \
--with-opengl-libs=/usr/include/GL \
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
--with-postgres=yes --with-postgres-includes="/usr/include/postgresql" \
--with-sqlite=yes \
--with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
--with-odbc=no \
--with-netcdf \
--with-lapack \
--with-blas \
--with-omp \
--with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
> Also note that when I run it from /usr/local/src/grass7_trunk -- where I was
> running it when I started this thread -- it succeeded.  It did not go into
> the infinite loop.
> * When the process starts, the first few lines read:
> ./configure: 229: ./configure: Cannot fork
> ./configure: 300: ./configure: Cannot fork
> There is a lot more I could send but have not, including the last lines
> before it restarts at the top of the loop.
> Please let me know what more information to five you or what changes I
> should make.
> - Paul
> On Tue, May 23, 2017 at 11:44 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
>> Paul Schrum wrote
>> > I started off trying to build it in a directory under my home directory
>> > using the instructions here
>> > <https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies>,
>> > but I could not get it to build.  The only part of those instructions
>> > that
>> > I was not following were the path.  So I started using the paths
>> > indicated
>> > in those instructions and then it would build.  That is why my copy of
>> > the
>> > source is where it is.
>> > Based on yall's comments, I now think it was something other than the
>> > path
>> > where I was storing the source code, but I have no idea what.
>> please post here your steps and error (?)/warning(?) messages of
>> compiling.
>> best regards
>> Helmut
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321504.html
>> Sent from the Grass - Dev mailing list archive at Nabble.com.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
