[GRASS-dev] [GRASS GIS] #3352: Behavior of v.sort.points
trac at osgeo.org
Sat May 27 09:01:49 PDT 2017
Reporter: spawley | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.4.0
Component: Addons | Version: unspecified
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
Replying to [ticket:3352 spawley]:
> Hello devs,
> I appear to be having some problems with the add on v.sort.points. Two
issues, potentially bugs:
> (1) the module fails if the 'cat' column is not the first attribute in
the table (i.e. if points have been generated from a database table),
returning the error:
> 'Error in sqlite3_prepare(): duplicate column name: cat'
Try r71147. This should hopefully fix that issue.
> (2) even if 'cat' is the first column, sorting by an integer column does
not appear to be sorting point datasets in numeric order. Example from the
nc_spm location:
> v.sort.points input=firestations at PERMANENT output=firestations_sorted
column=ID
> The order of the points based on opening the attribute table, and the
relationship between the 'ID' column and 'cat' appears to be the same as
the original dataset, where 'ID' was not in ascending order.
This is not a bug: cat values are conserved, i.e. the same points have the
same cat value in the input and the output. However, points are in a
different order in the file after v.sort.points. Category values of
objects do not define order.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3352#comment:2>
