[GRASS-dev] [GRASS GIS] #3352: Behavior of v.sort.points
trac at osgeo.org
Sat May 27 09:04:03 PDT 2017
Reporter: spawley | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.4.0
Component: Addons | Version: unspecified
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
Replying to [comment:2 mlennert]:
> Replying to [ticket:3352 spawley]:
> > (2) even if 'cat' is the first column, sorting by an integer column
does not appear to be sorting point datasets in numeric order. Example
from the nc_spm location:
> > v.sort.points input=firestations at PERMANENT output=firestations_sorted
column=ID
> > The order of the points based on opening the attribute table, and the
relationship between the 'ID' column and 'cat' appears to be the same as
the original dataset, where 'ID' was not in ascending order.
> This is not a bug: cat values are conserved, i.e. the same points have
the same cat value in the input and the output. However, points are in a
different order in the file after v.sort.points. Category values of
objects do not define order.
Try
d.vect map=firestations icon=basic/circle size=0.5 size_column=ID
d.vect map=firestations_sorted icon=basic/circle size=0.5 size_column=ID
and compare the two maps to see the difference.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3352#comment:3>
